QUOTE(somd914 @ Apr 28 2013, 09:29 PM)
My D-Jet harness connector has 5 sockets but only 4 are wired. The TPS should have five terminals (pins) also. The empty harness socket should be to the pin next to 17 Idle. The pins should be labled on the TPS but likely difficult to see without an inspection mirror. Anyway, the diagram for the TPS should be correct. Does this make sense?
OK, time to revise as your pictures did not come through until after I posted my above response.
So it does appear that your TPS has four terminals. I'm running carbs on my 2056 and took a look again at my spare 2.0 engine which no longer has the throttle body but the D-Jet harness is still there with a 5 pin connector labled "Throttle". I went back through my old photos from swapping engines and found this - my setup was different from yours...
I think it is time for someone else to chime in.
