jim_hoyland
Apr 29 2013, 05:43 PM
My '75 has started perfectly for many years; today that record ended. I had been checking my remote start button that mounts in the engine compartment. Started the car a couple of times. I then got in the car to move into the garage, turn the ignition key to acces position and NO dash lights, no accessories or lights would work. Turning the switch to the start position was useless.
The battery is good; I have power to the hot side of the fuse panel; the relays on the fuse panel are good.All the fuses are good as well
An I correct that the ignition switch is fried ?
struckn
Apr 29 2013, 06:39 PM
Magic 8 Ball says "Good possiblity". So for around $14 and 45 minutes to remove and replace, do it! The Tech Artical with pictures and step by step instructions that Pelican has was what I used on my '74 and it's really not a hard thing to do. My switch actually was cracked.
You have an Accessory Position on yours? Mine is only a 3 position, OFF-ON-Start.
Doug N.
jim_hoyland
Apr 29 2013, 06:54 PM
Mine is off - on- start too. When turned to the on position none of the accessories work,except the emergency flasher, dash lights don't even come on! Not even the oil or generator light...
Mike Bellis
Apr 29 2013, 07:40 PM
The power wire to the ignition is one of 2 wires that go from the battery to the front. One goes directly to the fuse panel and the other goes directly to the ignition switch.
wiggle the 4 red wires on the positive terminal of the battery. It is possible that one has come loose (the one to the ignition switch). Give them a good tug.
Bob L.
Apr 29 2013, 08:03 PM
If you have to take it apart, check the prong that engages the switch. They tend to twist backwards from the torque, causing a "no start" situation. It's probably not your problem now but You may want to deal with it while you're there.
Dave_Darling
Apr 29 2013, 08:15 PM
One word of warning: The 75-76 ignition switch removal is different from the 72-74 that's described in the Pelican tech article. I don't know how to remove the late style, though.
--DD
r_towle
Apr 29 2013, 08:22 PM
I don't buy the ignition switch diagnosis.
You were using a remote start switch and things work.
First, check the little red wires on the positive terminal at the battery.
Remove them, clean them, then re install them nice and spring tight....
Mine needed that every year, no idea why, but it gets cleaned now.
Rich
jim_hoyland
Apr 29 2013, 08:36 PM
