GulleyGulley
Apr 30 2013, 08:30 AM
I'm installing a 86 3.2 in my 6-conversion. I'd like to eliminate any of the vacuum lines, etc. that aren't needed. Car won't have heat, A/C, etc. Running stock fuel injection. I remember seeing a post that had pictures and notes of what lines can be deleted, but can't find the thread.
Cap'n Krusty
Apr 30 2013, 09:00 AM
I doubt there's a single vacuum line on the engine related to either heating or A/C. IMO, and I've worked on 911s for 40 years, everything on the engine related to F/I and ignition needs to be there for operation and driveability.
The Cap'n
Apr 30 2013, 09:23 AM
Except for the oe electric fan on top of the engine and the a/c compressor, I don't think there's much you can remove from the engine and still run stock FI.
jim912928
Apr 30 2013, 10:16 AM
There is stuff on the backside of the engine you can remove....if memory serves me it supports the vacuum lines for the brake booster and the cruise control (remember...if memory serves me right). See the attached pic of my engine basically stripped down and almost ready to go. I did retain the stock heater blower and just used the 914 fan housing (smaller diameter then the 911 housing) and thus cleared my engine lid. There were a few holes to plug.
Thing runs fine!
Jeffs9146
Apr 30 2013, 10:39 AM
I know it is not a 3.2L but I eliminated all of the decel valves and related vacuum lines and was able to eliminate some of the wireing that went with it!
So some stuff can be eliminated on a 911 and it cleans things up alot!
shuie
Apr 30 2013, 10:44 AM
Don't start puling vacuum lines unless you want to try to figure out why it wont start after you have it in the car.
GulleyGulley
Apr 30 2013, 11:16 AM
Thanks Jim. That back corner of the engine is what I was looking to clean up. Looks like you have one or two plugs where I have a hose coming out.
