Mike Bellis
May 1 2013, 06:45 PM
I tried a search here but got 47 pages of unrelated threads.
What is the best way to install new sway bar link bushings? Is there a how to?
PP web site has a "how to" install rear sway bar but does not mention how to get the new bushings in place.
Steve
May 1 2013, 06:51 PM
I used silicone grease and the biggest pair of channel locks I could find.
Mike Bellis
May 1 2013, 06:57 PM
QUOTE(Steve @ May 1 2013, 05:51 PM)
To install the new bushing into the link? Or to install the link on to the sway bar?
I need to install new bushings on to the link. Channel lock pliers sounds like damage.
r_towle
May 1 2013, 07:28 PM
Lube and a vice
442nd914s
May 1 2013, 08:18 PM
I would boil both the links and bushings in a pot over medium heat on a stove for 20 mins per link at a time.
After, leave 1 bushing in the pot (keeping it warm) while pounding with a rubber hammer into link. Now after a couple of minutes of pounding, you should be ready to repeat the process on the other side if drop link. Remember to invert/flip the drop link to the other side before you pound on it.
The heat from boiling water will soften the bushing into the slightly bigger drop link openning. If you take too long, the ambient air will cool them off and will be harder to work with. That's why its best if you boil one drop link & bushing set at a time.
Hope this help. It did for me
Eric_Shea
May 1 2013, 08:20 PM
Boiling water
Lube
Vise
Cuss
Swear
Done
JimN73
May 1 2013, 08:47 PM
Mike, if it isn't good after 20 minutes of boiling, add some pureed garlic, tomato sauce and spicy italian sausage. Simmer for an additional 2 hours and serve with pene pasta and red wine.
Steve
May 1 2013, 08:54 PM
QUOTE(kg6dxn @ May 1 2013, 05:57 PM)
Yep, that's how I got the drop links onto the ball on the shock
76-914
I just re-assembled mine using a large C -clamp. It might be a different ball game for new.
kwlane
May 1 2013, 11:23 PM
Boiling water, rubber mallet, pliers and just the right touch. First one took 15 minutes, the last one 15 second once I got it down. Wish I could remember exactly what angle I put it to get it to slip on...
