Help! Help! Has anybody out there got a clear schematic of a 1973 1.7L relay board that you can share (the one in the Chilton shop manual is washed out and blurry)?
I need one to try and figure out why I am not getting power out of the relay board to the fuel pump. I have 12 volts to the power supply relay (new) and pins # 30 and # 85 on the fuel pump relay (new). I also have continuity from pin # 87 on the fuel pump relay to the fuel pump, so the problem seems to be something that's not happening in the pin # 86 circuit of the fuel pump relay, and, due to the terrible schematic I have, I can't locate the problem. Any help/suggestions would be greatly appreciated.
