retrotech
Nov 24 2004, 02:57 PM
What is the best way to remove front hood springs? Hood is off.
Thanks,
Retro
SLITS
Nov 24 2004, 02:58 PM
Pry bar about 2' long......................and carefully
Nov 24 2004, 03:31 PM
QUOTE(SLITS @ Nov 24 2004, 12:58 PM)
use the top of the shock mount as the pivot point ...
pics in the haynes manual, page 198, lower left corner ...
Andy
TheCabinetmaker
Nov 24 2004, 03:36 PM
I use a 2' long piece of strong wire made into a loop. place it on the spring hook, hook a hammer handle thru the loop and pull gently and release gently. Works for reinstallation too.
Jeffs9146
Nov 24 2004, 04:53 PM
Nuf said!!
Jeff
mskala
Nov 24 2004, 05:00 PM
Brad told me a while back to just use heavy leather
gloves. I wouldn't have believed it but it did work,
I successfully moved them one notch tighter. And
I'm not an athlete. Of course, if you can tighten them,
you can take them off just as easily.
Allan
Nov 24 2004, 05:45 PM
I was wondering about that. I tried to pull them farther out so my hood (Bonnet for those of you who use such discriptions) would stay open. By the way, is this a common problem?
Nov 24 2004, 05:49 PM
QUOTE(Headrage @ Nov 24 2004, 03:45 PM)
yupp, that's why i got myself a set of 911 front hood shocks ...
Andy
McMark
Nov 24 2004, 07:00 PM
If I don't care about the black paint, I just clamp a set of Vise Grips just next to the coils and pull. They're not that high of tension. Of course I've got 200 lbs of weight to throw around. If you're a 120 lb lightweight it might be more difficult.
retrotech
Nov 24 2004, 07:12 PM
I put a carabiner on the end of the hook, then used a crow bar hooked in the other end of carabinet. Used shock stud for leverage, slight pull, and off.
Retro
Gint
Nov 24 2004, 08:53 PM
We just did this 6 months or so ago...
It's really much easier than it looks. Leather gloves, grab and pull. You'll be surprised.
