Mikey914
May 2 2013, 04:33 PM
I have a guy that bough a flexdam some time ago and needs the rubber now. As the rubber is a larger extrusion and there is not much margin on these I didn't do a bunch extra to have sitting on the shelf.
He needs the rubber, and I have to do a significant run to even get it down to this level, so I figured I'd try to get a few others interested to make tis happen.
The tooling is done and has been proven, it's just a matter of having enough interest to make this work. Who's interested?
Harpo
May 2 2013, 04:49 PM
Thank you Mark
Please everyone I need the rubber extension to go along with my flex dam
David
May 2 2013, 05:03 PM
I'm in for a set of both, the dam and the rubber ...
Gudhjem
May 2 2013, 05:13 PM
I'm in for both.
Harpo
May 2 2013, 06:20 PM
How many do you need for this to work?
Thanks again
DAvid
Steve
May 2 2013, 06:52 PM
I just need the rubber... Mine is trashed.
Mike Bellis
May 2 2013, 06:55 PM
I'm in for new rubber....
Is it UV rated?
scott_in_nh
May 2 2013, 07:47 PM
Can we see more pictures from you guys who have a Flexdam?
BuddyV
May 2 2013, 10:14 PM
I might be in for one of both..... would like to see how this looks on a car with flares
Anyone have pics???
BTW - thank you for making all of these cool parts. I have a bunch of your stuff. Always great quality and fair prices.
speed metal army
May 2 2013, 11:19 PM
The Flexdam! No flares though..
Click to view attachmentMarks stuff is top notch!
pjhaun
May 2 2013, 11:27 PM
How long is the rubber part?
Thank You!!!!!
Phillip J. Haun
Oak Harbor, Wa.
Mikey914
May 3 2013, 12:18 AM
QUOTE(Harpo @ May 2 2013, 05:20 PM)
Thanks again
DAvid
the Flex dams are 10 and the rubber is 20 pieces. The fiberglass should be no problem. I need at least one myself, I'm running it without the rubber, but this is mainly for making the rubber, and I figured a few people need these too, and there were a few of the old flexdams floating around that may need these for those. These are a direct replacement.
If I can get close on the rubber I don't mind throwing a few in inventory and charging a little more for them as needed.
-Mark
wndsrfr
May 3 2013, 09:50 AM
Will it work on Kermee? Here's a pic....in the pond at Roebling....sure needed a dam! How much ground clearance do I need? Kermee is pretty low......
I'd be in for the complete set!
ellisor3
May 3 2013, 10:49 AM
Here is mine. The new design is much better than the first run. The flex dam attaches much easier.
BuddyV
May 3 2013, 11:49 AM
Thank you, Ellisor3...... seems to work on flared fenders.
I am in for one of each.
jesiv
May 3 2013, 02:40 PM
How much for both?
May 3 2013, 02:54 PM
QUOTE(jesiv @ May 3 2013, 01:40 PM)
How much for both?
It's in the thread title ...
rfuerst911sc
May 4 2013, 03:57 AM
Anyone running one of these with a front oil cooler ? Just wondering if there is enough meat to the fiberglass to cut an opening in it for air flow to the cooler and maintain strength ? Also I'm running 993 style brake cooling deflectors is there still enough air flow under the car for brake cooling to still be good ? I may be in for a set based on the replies to my questions. Thanks for continuing to make parts for these vintage cars.
Jeffs9146
May 4 2013, 09:55 AM
Here is mine without the rubber!
JStroud
May 4 2013, 10:05 AM
I'll take a set, dam and rubber
Thanks
Jeff
Mikey914
May 7 2013, 08:40 PM
Just wanted to follow up on this.
The rubber will retrofit onto the earlier dams. So if you have a dam already you can mount to it.
The rubber is a more UV stable (than the organic rubber) and is compounded to be lighter and more durable that the original version 1st available in the 80's.
As far as fitting on car with an oil cooler cut out, yes it will fit, but you will need to cut it. the fiberglass is stout enough to support the rubber and you can make a modified opening using a light gauge sheet metal.
It looks like I need a few more interested parties to make this work.
blitZ
May 8 2013, 05:02 AM
What the heck, I'll have a set. Both damn and rubber.
7275914911
May 8 2013, 06:58 AM
I will be in for just the lower Rubber piece.
This should work nicely with a dam that had a splitter on it. My holes are already pre-drilled..
Rleog
May 9 2013, 10:55 AM
I'm in for a set, both dam and rubber, thanks.
FlatSix
May 10 2013, 02:30 PM
I'd like just the rubber please.
Mikey914
May 10 2013, 11:47 PM
Looks like enough interest to pull the trigger on the rubber, it'll go into production next week, and I'll have in about 3 weeks.
The flexdams themselves are rolling out starting today. I have 2 dams only ready to ship.
Mikey914
May 30 2013, 11:49 PM
treborzerimar
and
Steve
added from old thread
PanelBilly
May 31 2013, 12:22 AM
One of each for me please. Now I don't need to figure out how to flare the metal one
NS914
May 31 2013, 07:14 AM
Hi Jeff, I would be good for both and thanks so much for making these parts. Grant
B2524
May 31 2013, 07:25 AM
i'll take one of each.
PM with payment details when they are ready.
Thanks
Kent
Mikey914
May 31 2013, 09:16 AM
QUOTE(NS914 @ May 31 2013, 06:14 AM)
Mark actually but I answer to Mikey also,
THX
PlaysWithCars
Jun 2 2013, 02:35 PM
These look to be exactly what I've been looking for. I'm in for one fiberglass dam and 2 rubbers (seems these are a consumable w/ limited supply, might as well put one in inventory). PM me w/ price and shipping to 98038.
Mike Bellis
Jun 2 2013, 03:22 PM
My old rubber is falling off. I need new rubber!
When will it be ready?
Mikey914
Jun 2 2013, 11:06 PM
I actually got a novel idea and posted links to all my group buys with anticipated dates on parts.
I noted the fiberglass is available now and the rubber shortly.
Open threads with product shipping -
Title -Flexdam GB reopened, Flexdams at $105 rubber at $55
Anticipated product - Airdams in stock - Rubber 6/19-20
So 6/19-20th
Thanks for checking.
Mike Bellis
Jun 17 2013, 11:38 PM
stateofidleness
Jun 18 2013, 12:20 AM
Hey Mark,
Too late to get in on this? I'd be in for both a dam and rubber.
couple questions:
- how does it actually mount to the chrome bumper?
- is all hardware included?
- is that price with/without shipping?
- how do I pay?
Thanks!!
Mikey914
Jun 18 2013, 01:38 AM
Thanks for asking here's your answers -
---No, I will be sending out PMs very shortly as these are supposed to be ready this week.
couple questions:
---No. it mounts like the lower valance with screws
---Yes, I include the 5 screws and washers for the fiberglass section with purchase.
I also include 9 carriage bolts with washers and nuts to mount to the flexdam.
Is that price with/without shipping?
---Shipping varies with location, so these are quoted without shipping. I will be sending PMs asking for your zip code to quote shipping.
- how do I pay?
I'll send you a PM requesting your zip code and respond with a quoted shipping cost.
let me know if you need anything else, I'll be sending these as soon as I get the extrusion date.
-Mark
NS914
Jun 18 2013, 11:31 AM
Let me know as well re PM with payment details when they are ready.
Thanks again,
Grant
Mikey914
Jun 19 2013, 02:17 PM
these are close I should have next week
Mikey914
Jun 27 2013, 09:11 PM
The rubber is done and these are shipping I'm keeping the GB ope for another 14 days, so if you want one let me know.
Mike Bellis
Jul 3 2013, 04:22 PM
Got my rubber today!
Top quality and night & day difference from the original rubber!
Thanks Mark!!!
Mike Bellis
Jul 3 2013, 04:24 PM
Double post
PlaysWithCars
Jul 3 2013, 11:48 PM
Got mine this week! Air dam and flexible rubber. Parts look great, can't wait to put them on. Maybe this weekend...
NS914
Jul 4 2013, 01:58 PM
Can't wait to get mine! Mark is a great guy to deal with...very prompt and helpful re shipping etc. Grant
Steve
Jul 5 2013, 08:17 AM
I got mine!! Thanks!!
Mikey914
Jul 5 2013, 10:16 AM
You may have noticed that I included the mounting hardware
Steve
Jul 5 2013, 08:30 PM
QUOTE(Mikey914 @ Jul 5 2013, 09:16 AM)
What a nice guy!!!
stateofidleness
Jul 12 2013, 12:56 AM
Mark,
I see others have received their's. Can you PM me with shipping details on mine?
Thanks!
Mikey914
Jul 27 2013, 07:47 AM
I'm closing out the GB 8/5 One week left!
