I am in the process of planning for the removal of my engine to check a few things as well as replace the leaking front and rear seals. In the past, I have only done this in the short block stage where it was somewhat easier to over come any mistakes.
I am looking at potentially getting a short block from Original Customs but if that turns out not to be needed then the replacement of the seals is a must. I think I have the know how and proper instruction manuals. But I have not built an engine in 20+ years and there is no manual that comes close to matching the knowledge on this forum. So I am asking now instead of latter.
The engine is a 1975 1.8 (carbs as many probably know by now) with a 96mm big bore kit. I am suspecting that the PO did the top of the motor with the big bore install and left the bottom alone. A carb cam was supposedly installed but the condition of the bottom end does not entirely support a complete rebuild. Compression is good at 130 plus. It has a few minor drips from the push rod tubes which will be replaced.
But what else am I missing to check on the engine while it is out?
