QUOTE(mepstein @ May 5 2013, 01:08 PM)
QUOTE(Rand @ May 5 2013, 02:26 PM)
Check the MPS. If the hose isn't connected properly, or the MPS won't hold vacuum, it goes full rich.
MPS holds a vacum and hoses are new and tight.
I think you need to go through a totally methodical check of each component.
ie....when somebody mentions fuel pressure....it doesn't mean that the fuel pump is bad.
It could mean that your fuel pressure is wrong.
Also...and correlated...just because the CHT is new doesn't mean that it didn't go bad since.
Also has all the mechanical and wiring harnesses been checked and inspected including all the ground points.....
just saying...you need to be very methodical checking the D-jet system.
