raw1298
May 7 2013, 08:22 AM
I have been starting my car and driving in and out of the garage for about two years with no problems. Now I turn the key and nothing. Could the starter just quit like that? I have a battery tender on it so there is plenty of juice. Any ideas?
7TPorsh
May 7 2013, 08:46 AM
fuses?
xperu
May 7 2013, 09:01 AM
QUOTE(raw1298 @ May 7 2013, 09:22 AM)
Check all your grounding points and clean them. Mike
raw1298
May 7 2013, 09:05 AM
I'll check that again. The solenoid clicks one time, and itislike the starter won't turn.
ericoneal
May 7 2013, 09:18 AM
i had this exact problem last month. Have a look at this thread, maybe it will help...
starting issuesTurns out there was a relay on there that was fried. Since I bypassed that, my car has been starting better than ever. Do the screwdriver trick to see if your started is still good.
raw1298
May 7 2013, 09:29 AM
I have one of those relays on mine. I will check that out. Thanks for the info.
rgolia
May 7 2013, 11:34 AM
How about the seat belt bypass wire under the passenger seat.
May 7 2013, 11:38 AM
QUOTE(raw1298 @ May 7 2013, 08:29 AM)
Since those relays are usually added as a band-aid for a failing starter, even if it turns out to be the relay, you might want to look into getting a new or refurbished starter.
7TPorsh
May 7 2013, 11:39 AM
does the car bump start and run?
raw1298
May 7 2013, 03:45 PM
QUOTE(SirAndy @ May 7 2013, 10:38 AM)
I will most likely replace the starter before I put it on the road, so I might as well do it now. Any recomendations on where to get one?
TheCabinetmaker
May 8 2013, 08:47 AM
Anywhere but your flaps. Mexican rebuilt crap!!!!!!!!!!!!!!!!!!
I take all my starters and alternators to a local independent rebuilder. Search for one in your area.
Jon H.
May 8 2013, 01:48 PM
Give your battery terminals a little twist by hand and see it starts. If does then clean your terminals.
Jon
TheCabinetmaker
May 8 2013, 04:12 PM
QUOTE(Jon H. @ May 8 2013, 02:48 PM)
Jon
Then tighten it, cause it shouldn't move.
raw1298
May 8 2013, 09:32 PM
Terminals are very clean. I am assuming it is a combination of relay and bad starter. The gear connects with flywheel but starter motor won't turn. Will have to wait until Saturday to check further.
raw1298
May 8 2013, 09:36 PM
Thanks for all the help!!
raw1298
May 19 2013, 01:41 PM
Found time today to get under the car and check it out. I had a bad connector on the solenoid. Crimped on a new one and it fired on first try like before. Now to finish this project!!
Rand
May 19 2013, 02:14 PM
QUOTE(raw1298 @ May 19 2013, 12:41 PM)
Yay, another vote for doing the right thing instead of promoting the stupd starter relay band aid.
raw1298
May 19 2013, 02:18 PM
I will still replace the starter before putting it on the road. The one that is on it I got at a swap meet.
