brant
May 7 2013, 09:17 AM
I have a couple of spare MPS for a 1.7 Djet system
Here is the first one.
It has NO vacuum leak down and tests perfect
it is very clean
it has never been adjusted and retains the factory settings and seal
it has never been opened and is still factory riveted.
this is ready to bolt on
$185 shipped in the continental US
brant
Kaduku
May 7 2013, 11:03 AM
Are these interchangeable with a 1.8 with a D-Jet?
brant
May 7 2013, 11:22 AM
the 1.8 uses Ljet
the Djet MPS, can be tuned to run on any displacement, but there wasn't an MPS on Ljet (only if someone swapped out to Djet on a 1.8)
Kaduku
May 7 2013, 12:35 PM
QUOTE(brant @ May 7 2013, 10:22 AM)
the 1.8 uses Ljet
Well I guess my car is a Frankenstein. I was told my 73 1.7 was swapped out with a 1.8 in the 90s, but the DJet was kept in there.
brant
May 7 2013, 01:13 PM
That is completely possible.
Djet can be bolted onto a 1.8 and work well
its been done many times
ideally, the MPS would be tuned for the slight bump in compression
but the 1.7 and 1.8 are so close that it may not really need much tuning.... (maybe none?)
geoff would know probably from his experience in first hand tuning MPS for different applications.
I've had him tune 1.7 units with the wavetech for 2.0 motors
all of the units should be using the same diaphram, its just the settings that are changed between the 2.0motors and the 1.7 motors.
brant
brant
May 11 2013, 07:18 AM
bump
brant
May 14 2013, 01:23 PM
bump
luskesq
May 14 2013, 05:38 PM
Brant, I received one of the other ones from you last week. Although you claimed it wasn't as "nice" as the one you are showing here, it was very nice, zero vacuum leakage and electrically good. Thanks for the prompt and speedy shipment.
Keith
brant
May 15 2013, 10:10 AM
QUOTE(luskesq @ May 14 2013, 05:38 PM)
Keith
Thanks Keith,
I'm glad it arrived safe and sound
brant
May 22 2013, 01:42 PM
another bump
brant
Jun 23 2013, 08:28 AM
bump
brant
Jun 27 2013, 01:58 PM
no one is in need of a great 1.7MPS?
