JeffBowlsby
Nov 25 2004, 09:57 AM
They go up, but there is a delay of between about 2-10 seconds before the lights come on...no other issues. Might even be temperature related in that the delay seems longer the colder it gets. Any ideas?
The headlight motor relays only control the motors right? There doesn't seem to be any problem there, its just the lights don't light up right away.
Hep me hep me...
ClayPerrine
Nov 25 2004, 09:59 AM
The headlight motor circuit has absolutely nothing to do with the headlights themselves. They will come on even if the motors never come up.
Check your headlight switch, and the high beam relay. Both could have problems that would delay the headlights coming on.
davep
Nov 25 2004, 10:09 AM
Sounds like a relay problem, but it might be dirty switch contacts. Try replacing the relays first.
Gustl
Nov 25 2004, 11:16 AM
Other possibility would be corrosion at any contact within the headlight circuit.
I'd check the contacts at the back side from the fuse panel as well as the bulb sockets ...
Gustl
Nov 25 2004, 01:34 PM
QUOTE(davep @ Nov 25 2004, 08:09 AM)
but the relay for the light is under the dash!
the 2 relays in the front trunk are for the motor only ...
Andy
hargray2
Nov 26 2004, 07:09 PM
Replace the relay under the dash and clean the contacts in the relay connector. The lights should come on instantly and then pop up.
94teener
Nov 26 2004, 07:42 PM
The headlight switch contact pin 56 is by far the most likely contact to intermitantly fail or burn out. Make a short, temporary jumper wire to connect from pin 56 to pin 56K. If the lights come on instantly when you pull the headlight switch on, then make that jumper permanent.
Phil
