QUOTE(lsintampa @ May 8 2013, 01:48 PM)
QUOTE(Luke M @ May 8 2013, 04:19 PM)
Here's some pics of the rear but you should get how it works on the front from these.
Thanks for the pics. The hoses I'm talking about are for the rear. What my problem is the soft hose end is smaller in diameter than the hole on the trailing arm frame, so the clip isn't really putting any pressure on the TA at all, the hose just goes through the hole. So I was wondering if there is a washer on the hose side also?
My old hoses use the c-clip holders, but when I order rear hoses, I just get the ones like in my photo - one end takes a c-clip the other takes the spring clip.
From the sounds of things you have a later car which takes a different soft brake line.
What year is your car? I've owned both early and late 914's. The early cars takes the c clip on the chassis and the spring tab on the rear control arm.
The front is set up the same way. On the late cars they take two c clips at both rubber line mounting points. Again sounds like you got the wrong lines.
I have a set of early & late lines here someplace. I'll see if I can get my hands on them later today. If it helps I can post a pic of what I'm saying.
Pics added..
You can see the difference in the lines from early to late.
Early gets one c clip & one spring tab. The late two c clips at both ends.
