I've got to install a seat bracket before Cascade Lakes, otherwise I might not pass tech inspection.
Been looking at a number of different options.
First of all here are a couple of pictures so you'll see how much space (and angles) I have to work with.
Front view:
From the back at the top:
From the back looking down:
Was thinking about making an L bracket that I can bolt to the seat (the 2.5" section between the holes for the seat belts. I'll use something like a carriage bolt with a rounded head on the drivers side of the seat.
Found a couple of brackets for the roll bar that will work:
Or use a couple of these with the same L bracket
Coleman also makes a parallel one that might be easier to bolt up to the L bracket on the roll bar side.
Good way or is there a better way. All ideas appreciated!
