QUOTE(AE354803 @ May 17 2013, 05:25 PM)
QUOTE(r_towle @ May 16 2013, 10:33 AM)
Djet can go up to 2.4 liter with the 71mm stroke (stock) crank.
That is 103mm pistons.
It cannot deal with a longer stroke.
rich
Rich, just a curiosity, why can't the Djet system deal with a longer stroke?
If the capacity of the engine is the same why would it matter whether it was because of a larger diameter or a longer stroke, the FI is most concerned with the flow of air into the engine? I would expect the flow rate of air into the cylinder to be essentially the same at a given RPM if everything else was identical.
You can see from the graph that the change in volume (flow) into cylinders follows the same basic path. (the 103 mm x 71 yields a larger displacement than 96 mm x 78.4 but even if it's changed to 101 mm it still follows approximately the same curve) You can see how the rod length affects the curve by essentially flattening it as length increases.
Again I have no idea, but this surprised me.
Andy
Click to view attachmentDunno, but btdt with both, one can be tuned, one can't
It's measuring manifold pressure, not air flow on diet.
I tune them on the road with a/f gauge, and seat time, up and down the roads while tuning.
A lot less precise than all the data collecting, but it work as well as it always has, and the motors run great.
Not looking for the ultimate hp , just a decent motor that does not require 2k worth if fuel injection, or a homemade mega squirt setup....
I have heard that ljet can do more, and air flow is used on the 944 and 911 with less of the issues that manifold pressure introduces to the whole scene.
I heard loads of myths when it came to what diet could do, and I , like you, could not understand why it would not go bigger.
So, I did it, more than once.
It's fun to try for me, and I am now breaking in my motor on carbs before I tune the djet for it...
I have built two other ones and tuned them, I learned a lot about wht works on these...and my motor I tried a different cam to see if I can get around another djet issue with overlap and flutter in the manifold...
Honest I don't think this motor will be able to run djet, but I am going to try anyways...
Rich
