So with the stock axles that use the c-clip to anchor the cv assembly, versus some of the custom built ones that allow the joint to self center and float. Should the axle be expected to have some float from end to end(by hand) to compensate for the change in length through the arc of movement?
I've noticed that the axles have float when the car is in the air, but not when on the ground. My axle set up is custom without the c-clips and has worked well for a number of years. I started getting a circular grind noise for nano second today under some g-force turns. So I went looking. never noticed the tight axles (playwise) before and had me worried. Hoping it was gravel from the parking lot 20 minutes earlier. I've not ruled out suspension console/bushing movement contributing to end load onto the joint, but i'm looking for ideas.
Thanks.
