Full Version: Cloth Braided Hoses
913B
I am need of the 1/2 diameter and 3/16 diameter for vacuum, trying to replace 40 year old lines in my engine compartment.
Any good sources out there, cip1 has the 1/2" but not the smaller one.
Anyone ?
Thanks in advance.
Ted
Cap'n Krusty
GPR.
And, just so you know, they're metric, so that's 12mm and either 3mm or 4mm, depending on the application
The Cap'n
damesandhotrods
Do you have any air cooled VW parts stores in your area?
reharvey
Try Belmetric.com
euro911
Ted, ISP West in Carson also has the stuff.
cary
When I order a bunch I order from Pelican (old habit).
When I need one hose I shop at the bug shop in Portland.
Discount Import Parts.
VaccaRabite
be careful with the cloth braided hose. It is not rated for ethanol, and you have to check them every season for cracks now. degrades really fast.
QUOTE(Vacca Rabite @ May 19 2013, 09:17 PM) *
"I am need of the 1/2 diameter and 3/16 diameter for vacuum, trying to replace 40 year old lines in my engine compartment. "
- Shouldn't be an issue for vacuum hoses, right?
VaccaRabite
Yep. you are right. Just saw cloth hose and assumed fuel.
Zach
euro911
agree.gif The cloth covered stuff is fine for vacuum lines.
I always run the hi-pressure FI rated hoses for fuel even when running carbs.
LotusJoe
QUOTE(porsche913b_sp @ May 18 2013, 10:17 PM) *
Anyone ?
Thanks in advance.
Ted
Good local source is McFadden Dale Hardware
