Need some help? Built a 2056 from a 1.7 (Duel 40's) (I have about 1,000 miles) and all has gone well great results. Notice a high heating issue 220 up to 230 oil Installed a oil cooler plate type with oil filter and remote cooler and fan. I'm not seeing a lot of additional cooling? Today went out for a drive and temperature zoomed up to 240, 260 and shut it down. (I was also getting a good pinging sound from the engine) To be safe called tow truck to get the car back home. After a hour to cool down fired back up like nothing happened?
Ideas: Can you install oil cooler upside down ? and will it block oil flow
What I'm going to do is remove oil cooler and see is if heating issues persist.
Could this be a timing or valve adjustment problem with heat? Any help would be great.
