cary
May 19 2013, 09:04 PM
Once wondering if there is a trick to brushing on the seam sealer?
Used the horse (?) hair HF ones first. Not real happy with the look.
Do/can you cut it with some sort thinner to get the factory look?
bulitt
May 19 2013, 09:20 PM
Dip the brush in acetone then brush the sealer into the cracks.
rick 918-S
May 20 2013, 07:22 AM
Lacquer thinner works. We call the brushes Acid brushes. They have a metal tube type handle.
cary
May 20 2013, 08:25 AM
Gotcha................
Should be able to find them at HD with the soldering stuff.
Thanks.
URY914
May 20 2013, 08:38 AM
You can find those cheap brushes at the discount tool suppliers. Harbor Fright, Northern Tool, etc. You use them and toss them.
