Full Version: Idle issues
Car starts immediately with 1 turn of the key. Idles at a steady 900 rpm at first but increases to 1800-2000 as it warms up over 5-10 minutes. Drops down to 1600-1800 after about 20 minutes. Still too fast. It's been 65-80 degrees here.
Help please.
Anyone?
JawjaPorsche
Without being there, my first guess is a vaccum leak or your AAR.
saigon71
Can't completely rule out a vacuum leak, but the fact that it happens as the car warms up makes it sound like your AAR is stuck in the open position.
Check out this site & cruise down to the troubleshooting section:
http://members.rennlist.com/pbanders/djetparts.htm
On the bright side, the AAR is pretty easy to pull off and bench test.
Good luck!
TheCabinetmaker
Pull the aar hose and plug it. idle goes down? problem found.
I will do as you guys suggest. Thanks
