QUOTE(PDXMike @ May 22 2013, 05:15 PM)
My '75 1.8L has a Monza (I think) muffler. There is a tab on the muffler that looks like it is meant for a hanger, but I don't see any corresponding mounting features on the bottom of my car. Is there something missing from my car? Do I need to fab up something for the underside of the car? Do I even need a muffler hanger in this set-up? It seems like a lot of weight hanging off the heat exchanger flanges.
The exhaust hanger should bolt to the exhaust/heat exchanger flange interface, and then to the back of the transmission. Its hard to tell in the picture, but it looks like you have that already. If not, do NOT try to run it or even have the muffler installed. You're right, all the weight on the heat exchangers alone is a good recipe for pulling exhaust studs out of the heads. I think the hanger should be sufficient, even with a Monza exhaust as long as everything is tight and in good shape.
