Full Version: crankshaft bearing dowel pins
Natedog
Hello -
So I've started my first engine rebuild and I have a question:
I have a 73 2.0 litre 914.
On the crankshaft bearings, are there supposed to be small dowel pins holding the bearings in place? The Haynes manual shows a diagram with the dowels but they aren't mentioned in the reassembly directions. The dowels ( 4 total ) should be about 5 mm diameter by 8 mm long.
Do I need them?
What's the correct size?
And where can I get some!?
Thanks for your help!
Cheers
Nate
Fort Collins CO
73 914 2.0
73 VW T3 Squareback
Allan
They keep the bearings from spinning. Not sure where to get them. You might try Jake Raby.
Brad Roberts
Yes you need them... Why/how did you lose them ??
B
Aaron Cox
MattR
I think aircooled.net has them. They're a standard off the shelf part, iirc.
Natedog
Thanks!
Is this the right part:
Part #: ECA0014
on aircooled.net
I'll need four total right?
I don't know if this link will work, but anyhow....
http://aircooled.net/new-bin/viewproductde...127200440613509
TheCabinetmaker
Hey Nate, just noticed you live in the Fat Tire capital of the world. beer.gif beer3.gif beerchug.gif drunk.gif
Jake Raby
HELL YES! You need them!!
They are actually there to align the bearings correctly in the saddles to match the oiling passages, not really to keep them from spinning- The align bore crush takes care of that..
Not only are they a must, but they also should not be longer than 8.0mm, if they are they will protrude too far into the bearing and will pich up when you torque it down and wipe out a bearing and piss you off the first time you try to fire it up!
I have thousands of them if you can't find any..
Britain Smith
What exactly does it look like when the crank is shuffle-pinned?
What is the advantage of this?
-Britain
Jake Raby
Shuffle pins go around the case through bolt bores and have an interferance fit that locks the case halves together and keeps the case from "Shuffling"
We only do it for engimnes making more than 200HP.
