QUOTE(Mark Henry @ May 25 2013, 07:35 AM)
I'm getting that all the time when I post as well, doesn't seem to load, then you press "add reply" again and it double posts.
Well thanks for fixing that.
Back to topic I find that gm has filed patents addressing this with main bearings. They found that a very high beryllium aluminum alloy would produce an expansion coefficient like steel. Proposed it for bearing caps.
As to the film, how thick is it by the time the warm up is complete?
