So I have a web cam, and it isn't stock. So I tried stock timing at 3500 , and I tried timing using a vacuum gauge. I tuned it to 19 inches of vacuum with a steady needle and then backed off to about 18. That seemed to run too hot even if vdo isn't reliable. Now I have changed so I am pretty sure I am retarded
Is there a method? Am I correct in thinking that changing the cam compression ratio and cylinder volume might make the stock timing marks less relevant? Help? Oh, and thanks to all.
