Hi everyone!
I'm about to put my working 2.0L 1973 engine and transmission into my 1972 914. I want the 73's improved shifting. I salvaged almost everything I needed off my 73 before I scrapped it.
Is there part or procedure that I have not listed here that you reccommend before I reinstall it?
Engine Seals to replace:
Pushrod tubes o-rings/seals
Front & Rear Mains
Oil cooler seals
Oil Pump cover seals - may be complicated….investigate.
New! Oil cooler?[size=2]
Engine Mounts - (Probably not)
Rubber grommets for all engine tins and electrical wires to pass through.
Engine sealing rubber strips along sides of body. - Not needed
Rubber seal for top rim of rear engine tin work.
Clips that mount to rear engine tin that holds wires on the transmission side.
New thermostat for air cooling system, make sure system is running.
Valve Adjustment
Transmission:
Flywheel hold down tool
Clutch alignment guide tool
bearing that goes in the flywheel. -Mine was in bits when I took off the flywheel
Thrust bearing?
New Clutch?
Investigate other issues?
flywheel bolts
Also get:
trade out for "new" alternator,
alternator rubber bits for cooling etc. (2 things?)
Alternator rubber air cooled connector to fan housing.
Alternator belt (have)
Exhaust mounting studs and bolts (to engine)
exhaust gaskets? (heat exchanger to engine)
PARTS NEEDED FOR 72-73 2.0L ENGINE AND TRANSMISSION SWAP
'73 shifter - own
'73 shift rod - own
'73 transmission - own
Flush and refill transmission - (with what?)
Engine mounting bolts for the frame. -1973 version
gasket for shift rod
This engine was already running on carbs so no fuel injection stuff is needed and I've already overhauled the carbs and had them working before I salvaged the engine.
Thanks in advance for everyone's input.
Stephen
