QUOTE(ChrisReale @ Nov 27 2004, 11:17 PM)
Doubtful. That tear looks like it is because the through-hole was not supported properly.
This is an area to keep an eye on.
The original front bars had the sheet metal doubled-up in the mount area. The nut plate is not a doubler, IMO. Even if you install the doubler on a car not so equiped, big tires/springs/AR bars were not part of the equation during the design process. This area should part of the inspection process after each AX....or at least inspected often.
All of the 911 rear AR bar failures that I have seen (or heard of till now) are at the body mounts....both aftermarket & OEM installs.
Again, a big honkin' rear AR bar (along with all the other stuff) *may* over stress the cheesy reinforcement/mounts of the 914 set up. Should I ever get an LSD, I'll worry the rear AR bar deal to come up with something.
Let's face it. Most everything we do to these 30 year old cars is overstressing the chassis. All this emphasis the suspension "stuff" overlooks the platform that supports it and I'm as guilty as everyone else. We're living on borrowed time.
Most failures don't happen in a heart beat.....little cracks turn into big ones, then "crunch".....you have a mess. The Mark II eyeball is your best defence.
