QUOTE(jmargush @ May 27 2013, 10:01 AM)
I really need .016 but the only shims I could get were .010 and .020.
So would it be ok to remove the standard shim and just run the .020?
I guess what I am asking is can the thicker deck height shims replace the standard or do you still need to use the standard for sealing purposes?
You can use up to 3 shims, I'd run the .010 and the standard which IIRC is about .008.
Only place I used to use RTV is under those shims, some use curil derko (basically same as RTV) or threebond.
