I have been doing research on the forums about taking out the oil strainer and cleaning it and putting it back in.
The Cap'n said to use only 9 lbs of torque on the bolt plus not use any sealant on the gaskets.
I got the Victor Reinz Oil Gasket Set. (See picture) It comes with two gaskets do you use both of them? I know where one goes (strainer cover) but how about the second? Also the washer, does it replace the existing washer?
Also does the strainer just fall out after taking out the bolt and strainer cover or do you twist or thread it out?
I know these questions may seen very elementary to some of yall but if there is a way to screw this up I will!
Thank you so much in advance for your help and advice.
