I had a request to find all the group buys and it seems most appropriate to post the open threads here. So as I add them, I'll list them. If you want in on an open thread, just add to it (you can PM me but I'll probably never find it).
I do want to thank everyone here for supporting my efforts in making these parts, it's been 5 years and I went from 1 part to over 130.
Sincerely
Mark W
AKA Mikey914
___________________________________________________________
I realize there are a few threads that I've got open as GB's that are being fulfilled very slowly or being refined further they will be added in as they are brought up to speed
Current open threads with product open and shipping
Parts in production -
OEM style front turn signal seals
http://www.914world.com/bbs2/index.php?sho...mp;hl=Group+buy
Front trunk pull with sheath
http://www.914world.com/bbs2/index.php?showtopic=236741
Sway Bar bushings
http://www.914world.com/bbs2/index.php?showtopic=236676
Wiper grommets
http://www.914world.com/bbs2/index.php?showtopic=236670
Door light switch gaskets
http://www.914world.com/bbs2/index.php?showtopic=236674
Hand throttle for carbed cars GB $120 maybe less $99?, My source in Germany has discontinued now I'm stepping up
http://www.914world.com/bbs2/index.php?sho...29649&st=25
Group buy 2.0 throttle body to plenum rubber sleve, 039.133.073 ? $10.20 these will be $16.80 after
http://www.914world.com/bbs2/index.php?showtopic=231660
Group buy wiper assembly offset standoff, $6.80 each, $12 after the GB
http://www.914world.com/bbs2/index.php?showtopic=231661
New rear targa seal with fuzzie-
http://www.914world.com/bbs2/index.php?sho...=220677&hl=
Anticipated metal inserts available 3/22
Open threads with product shipping -
Yes another GB Side marker lens seals, a set of the "new and improved" $8 (for both) $12 after
http://www.914world.com/bbs2/index.php?sho...amp;hl=triangle
Closed GBs
> LAST DAY- The coveted triangle window seals! Closes Feb 14th, GB $92 a set..+shipping. Yes left and right! ? $120 after
New parts that I'm making - Carpet grommets, GB-$4.40 large , $2.99 for the ones that hold the front carpets anticipated 10/18/13
link-
http://www.914world.com/bbs2/index.php?showtopic=211270
Heater lever cable nipples -
http://www.914world.com/bbs2/index.php?act...=0#entry1934252
Another GB - $8.40 a set Water drain grommets, The ones for the hoses on the funnels.
http://www.914world.com/bbs2/index.php?showtopic=216019
GB- The original window scrapers, These are the ones correct for the 6's
" New" old style window scrapers $8.50 each (you will need 2).
http://www.914world.com/bbs2/index.php?showtopic=217109
Another GB Trunk lock gasket Will be ready W turn signal boots, $2.75 + shipping
will be ready with turn signal boots
link-
http://www.914world.com/bbs2/index.php?showtopic=213720
Thread title-
I think everyone may want these - New part GB, Turn signal crack pipes (rubber cover boots) $26 a PAIR!!!!
link-
http://www.914world.com/bbs2/index.php?showtopic=211358
Title -Flexdam GB reopened, Flexdams at $105 rubber at $55
Anticipated product - Airdams in stock - Rubber IN STOCK
link-
http://www.914world.com/bbs2/index.php?sho...209472&st=0
Shock cap covers- thinking of making these, Who's interested at $9.99 a set?
link-
http://www.914world.com/bbs2/index.php?showtopic=200727
GB -Eyebrow grommets set of all 4.99, Made from silicone easier to install
Link-
http://www.914world.com/bbs2/index.php?showtopic=207560
GB - $8.20 + shipping the Side shift rear bellows was NLA, Fits at the rear over the rod at the plastic cover --GB closes June 16th
link-
http://www.914world.com/bbs2/index.php?showtopic=207565
Snorkel Tube wiring harness GB $28 each, These will be $45 after the GB
Link-
http://www.914world.com/bbs2/index.php?showtopic=200378
GB - front trunk "nose plugs" set of all 9 - silicone, $22 a set will be $40 a set after GB
Link-
http://www.914world.com/bbs2/index.php?showtopic=207561
Fiberglass door panels with vinyl
http://www.914world.com/bbs2/index.php?sho...fiberglass+door
