QUOTE(jfort @ May 31 2013, 09:13 AM)
I think I have something drawing on the battery when the car is idle. I have a good voltmeter and an academic understanding of the principles, but I don't know how one measures amperage without "being in the circuit." More specifically, I don't know how to measure, or at what point to measure, whatever current is flowing out of the battery even when everything is off. Guidance?
What may be happening is that the voltmeter is falling as you reach idle. You did not mention volts. If it is falling from 13 to 12, then it is normal. The alternator is pushing a small amount of current through a charged battery at 13 volts when running and then gets tired of doing that at low revs - revealing your true battery charge. It should be the same number if you turn off the key and leave the ignition on.
On the other hand, if it is dropping down to 10 it may be that there is truly a load drawing the battery down, or it may be that the battery is not able to put out that much despite the charging efforts of the alternator. If it is the battery, then the voltage across the terminals will not change if you shut off the engine and disconnect the wires.
If it is a load, then the voltage between the battery terminals will be higher when the engine is shut down and the terminals connected, than it is when you hook up the wires.
My alternator is new with new regulator and still won't really kick in till well over 1500- more like 2500. Then it runs fine.
