I bought this car about 6 years ago to do a simple restoration. As I went along, I decided the original air-cooled flat four wasn't enough engine, so proceeded to install an all aluminum Buick 215 ci V8. The stock engine was completely rebuilt and lived for about 6,000 miles in a TR8 before being yanked for 914 duty. At that time, the engine was gone over and new rod bearings installed just for the fun of it. It was also fitted with a Ford truck EDIS ignition system in order to eliminate the distributor, which allowed the engine to move forward without intruding into the bulkhead. The ignition is controlled by a Megajolt programmable controller, which allows fine tuning via laptop to accommodate a variety of parameters. Carb is an Edelbrock 500 4 barrel. It exhausts through Rover 4.0 stainless steel tubular headers (this thing sounds soooooo sweet). The stock water pump was modified as an intake plenum for an electric cooling pump, again to save space at the front of the engine, allowing it to be situated forward and minimizing the anglular distortion of the CV joints. The engine in its current tune is good for about 200 HP, about double the output of the stock 2 liter, with almost no weight penalty. It's mated to the stock Porsche 901 transmission via a Kennedy adapter plate.
OK, the rest of the car...
The original rust was not bad, but bad enough to require attention. The hell hole has been completely rebuilt with fresh steel, as has the longitudinals. The floor pan was in pretty good shape, but any hint of rust was cut out and replaced. Corners were gusseted for reinforcement. Wherever any body or structural repairs were made, it was finished off with Rust Bullet.
The car is equipped with front and rear sway bars. The rear control arms were boxed for stiffening and new rear wheel bearings and shocks installed. All four corners were converted to five lugs and fitted with replica 15" Fuchs wheels and brand new Falken 225 tires.
Interior is in very good condition without the usual dashboard cracks. The console is a custom design with gauges, switches and start button. on brushed aluminum.
The body is fitted with GT flares and painted a metallic bronze. Paint is OK, not great. All glass is flawless.
OK, here's the reality...I've been working on this thing for the past six years and it still has issues that I just can't get past. The engine is quirky. One day it runs fine, the next day it barely starts. Electrical/ignition checks out fine so I'm suspecting a fuel problem. Cooling is also quirky. I know the system is up to the task because when I manually switch the cooling pump on you can watch the temp drop dramatically. However, it'll climb to 220* before it drops. I don't like to see 220*. Oil pressure is low. I bench ran the engine before putting it in and the OP was right on spec, but now it shows an abnormally low reading. No bad sounds come from the engine indicating low OP, but it just isn't much fun looking at low pressure. Right rear tire has a slow leak. I know I should take it in and have it fixed but I keep thinking it'll fix itself. Yeah right. I installed a fan and pump for cabin heating, but haven't figured out a way to duct the heat from the front trunk area to the cabin.
OK, so here's where I'm at. I poured my heart and soul into this car for the past six years, to the detriment of my family, my bank accountg and my sanity and, as cool as it is, it still has the issues I mentioned above. Bottom line, I'm out of patience with the car and want it gone before I'm tempted to delve into it again. I've got two other toy cars that have been neglected due to the time and expense I've put into this 914 and it's time to move it on to a new home that will love her and drive the crap out of her as she was meant to be. I'm very flexible. If you'd like to buy the car as a roller and restore her to the original flat four air-cooled engine, it can be done. Personally, I think this would be a dynamite track car. $5500 complete, $4000 as a roller. 920-seven four three-9727.
