QUOTE(Randal @ Jun 3 2013, 04:09 PM)
OK, so what's the best sequence for doing the alignment?
This has worked well for me:
- Disconnect any sway bars you may have
- Roughly set ride height to where you want it to be
- Brake tie rods lose
- Make sure your scales are level, don't forget to check cross levels
- Roll car onto your scales
- Lock steering wheel down in center position (do *not* use the key lock, if you still have one)
- Make sure your tank is about 1/2 of what you would start with at the beginning of a race/AX
- Corner balance the car with your weight in the drivers seat (don't forget gear!)
- Adjust camber and caster
- Adjust toe
- Tighten tie rods and rear bolts
- Reconnect sway bars, make sure you do not introduce any preload
- Double check camber/caster/toe
- Drive!
