QUOTE(skline @ Nov 28 2004, 09:40 PM)
I'm sorry Andy, I have to bring up a question before that question could be answered, the most common engine in a 75 was a 1.8, the 73 didnt have the 1.8 option and therefore it had D-Jet injection, the 75 1.8 liter had L-Jet unless it was a 2 liter engine in both the 73 and the 75, the injection system is different. In which case, he would have to change the entire injection system on the engine.
the '73 2.0L D-Jet will work on a '75 2.0L core and vice-versa ...
1.7L D-Jet will run just fine on a '75 1.8L (that's what i had in my car!) ...
he didn't specify the size and injection of either the old or the new engine.
if they're are the same size (which i assumed) the injection, brain and everything is interchangeable.
you can also switch injection types between different size engines as long as you use a complete induction system.
again, i assumed he had 2 same size engines ...
Andy
