QUOTE(SirAndy @ Jun 3 2013, 07:10 PM)
QUOTE(r_towle @ Jun 3 2013, 03:55 PM)
Simple.
Have Mcmark put an inline shutoff to the cooler, one you can reach.
I was thinking about something similar. A flap in front of the cooler that is operated by a cable would suffice.
Take a look at an original volvo PV 544.
They have what looks like a window shade mounted in front of the radiator.
(Think about the temps they see in northern Sweden)
Anyways, its really a simple design.
Roller at the bottom, slides on the side.
Pull up the shade to stop all air, or just partway, all depending upon what you want.
Cable runs from the shade, up over the engine, all the way to the dashboard.
The end of the cable is a chain made up of 1/8 inch "ballchain" the kind with one ball connected to the next ball.
The lock is simple...it is shaped like a keyway.
Round and the top, with a slot at the bottom.
Pick up the chain, get it into the round area...pull to adjust.
Slide into the slot and one of the balls locks in place.
Its elegant and simple...
There is a spring in the roller so when you unlock the chain, it wants to roll down.
I was originally thinking of putting a shutoff valve inline, and within reach of the driver for the oil lines.
I think the window shade would be safer.
rich
