Alright dude-I have some experience with these--If you truely want to keep your car slammed -AND- have a decent ride quality here is what you should consider doing.
1. Take the tops off the struts and put in a SECOND set of rubber springs.
2. With the car's front end off the ground, back off on the adjuster all the way until you can actually get it off, Loose the top of the strut so it hangs from the adj. plate by about three threads from off on the rod nut.
3. Now is a good time to make sure you have the proper torsion bars in place (marked R & L ) the L one has more tension to compensate for the driver.
4. Now as best you can work that adjuster back into its home so as it is fully bottomed out, i.e. no possible pre tension adjustment yet. When that is accomplished, tighten the rod nut to bring the strut/ arm back under pre-tension.
5. Now, the best way to do this is get four pieces of metel plate, two per side, with grease in between the plates so when you lower the car front tires onto the plates , they slide and allow the sus. to go to its driving point immediately, if you do not do this, each time you raise and lower the car you will have to push it back and forth to get the front arms to settle.
6. With the car lowered in ints most un-adjusted position, measure from the ground to some point on the car that can be reproduced perfectly each time.
7. Now it is a simple matter of finding your "ideal" ride height. I am 225 lbs, keep the fuel tank full as possible, ( this has dramatic effects on such a light car, set the sus. with a low tank and when you fill it, you will NOT be happy with the results) But for me, I turn the adjusters, ( front off the ground) until I have 1 1/4 inch raise on the rightside and 1 1/2 inch on the drivers side. My car is still slammed, the extra rubber shocks help to cushion very well, handles identically in right and left turns, and I run KYB's also. Happy trails, hope this helps you out
