I actually don't think the man is "too intense" at all. I think he is a terrific mechanic that, once I was in person, explained it much more clearly.
Rust (probably not going to be able to do pics for a while):
Firewall-clutch tube pulled through and he didn't feel he could repair it as he had on many other 914s
Floor is oddly rusted from the top down rather than the bottom up, but also from the bottom. Both inside and outside floor (in my simplistic terms) are "gone" but replaced with interesting solutions.
Front end: Parts replacements would fix this. (Control arms mangled, ball joints) .
Body issue: There is a place near the rear of the driver door sill that has a not so good weld. When you close the driver door, the windshield frame flexes forward at the top a bit. This was not noticed until I replaced the rubber stuff.
His call (Don at Don's Autowerks) was that it might be less expensive to find an excellent donor tub (1975 or older) and move everything given the cost and complexity of the repairs. . . although someone else might want MY tub at a lower cost once it is naked . .to save it.
Thanks for all your comments and help and offers to do a parts switch once a donor is found. . . and what type of seared flesh and barley pop would be specified
Sean
QUOTE(montoya 73 2.0 @ Jun 4 2013, 11:46 AM)
QUOTE(SirAndy @ Jun 4 2013, 10:51 AM)
QUOTE(mrholland2 @ Jun 4 2013, 09:29 AM)
well, this was the guy that I was told to use. . so, maybe I need more "grounded" advice or a less intense person to scrutinize it??
Now we need a name. Who is this person that is "too intense"? Out with it ...
and we still pictures!
