Not sure what generation you are, but I have tuned carbs for years by reading plugs.
Reading plugs isn't what it used to be with today's fuels. Also, a big factor for me in moving from the relatively inaccurate Colortune to egt probes was stripping out a spark plug thread. -I cringe to hear people taking out plugs hot, which is the only accurate way to read plugs.
So, one sensor and gauge is a whole lot more than I ever had...and one does work.
Not everyone can afford everything and the OP is looking for a cheap solution.
It all depends on how well you want it to run We've talked about several options and price points here from an infrared gun to thermocouplers to probes.
One sensor will work if that is what he can afford...
A single sensor and a single gauge.
Again, best save your money on that.
Oh, btw...I do know how they work.
I don't really, but the tc amplifier is like a preamp in an audio system it would seem.
Carbs a far easier to tune than EFI' so don't over think it.
Again, it all depends on how well you want it to run. It's easy, sort of, to make it run, but to make it run well... I don't see that much. Most people's carbs run like pigs. Richness hurts performance. Carbs are forgiving, one should say, not easy. There is a lot of performance and drivability to be had just through tuning.
Based upon your elevation, your camshaft, and your head combo, I know at least five people that can give you a very decent base setup for carbs that will be damn close to right on the money.
The issue isn't jetting here, it's setting up the mixture, air correction, and the linkage. There are plenty of variables to be considered.
You may be over thinking this and you might want to spend your small budget on other more important things than a gauge you may never really need.
Agreed... about the budget.
The innovate option is crap and the next level up is fairly ridiculous in price. I do recommend, if you have carbs, get an infrared gun and aim it at your exhaust stubs.
