QUOTE(scott_in_nh @ Jun 5 2013, 04:03 PM)
QUOTE(r_towle @ Jun 5 2013, 03:47 PM)
Get threaded spring perches for the Koni shocks.
You can set the ride height and get the added benefit of real corner balancing. The threads slip over the shock body and rest on the retainer...then you place the perch on the threaded nuts...
You have to build your own from these guys, but its the basic parts and its as cheap as you can find it...otherwise you end up buying a kit which has mark up buring in there.
You can also go down to the 2.5 inch diameter springs at that time, or later on...the springs are cheaper, and tons more available.
I might suggest you do what I did for a few years.
Night before the car would be lowered, race tires etc.
You could easily swap out rear shocks (complete with springs) the night before the event.
Raising and lowering the front is just accurate measurements.
Leave the alignement perfect for the raised setting (daily driver) and deal with it when you race...you can learn it pretty fast.
http://www.colemanracing.com/Shock-Sleeve-...tein-P3700.aspxRich
Of course you are right Rich, but what a slippery slope!
The springs may be cheaper, then then I need top and bottom spring perches right?
Just doing the adjusters adds $100 to the job....
Yup. Tis a slope, and its steep and slippery.
By this time next year, your car will have a whole new suspension...and wheels/tires...
But, with a bit of effort, and piece of tube steel from home depot will do what you want...
Needs to have the ID the same as the OD of the shock body.
If you have welded perches and not adjustable perches on the Koni's you can carefully cut off the perch and leave the heavy round shelf.
Piece of pipe, perch, spring...done
If you have adjustable perches on the Kon'is a piece of pipe is all you need...simple.
I wanted to to see all the parts you can buy...then your mind will come up with a solution that works for you...just see how they do it based upon all those pieces and parts.
Now, how important is that ride height????
An inch may be with alot of effort.
Decisions Decisions....
rich
