QUOTE(--axel-- @ Jun 5 2013, 12:45 PM)
QUOTE(SLITS @ Jun 5 2013, 12:41 PM)
It is the clutch pedal stop and is mounted to the pedal board at the top of the clutch pedal hole in the board.
Thanks. I just noticed that the bolt spacing matched the board hole spacing. Does this go behind the board, or on the pedal side? It appears that the nuts I took off go to the inside and didn't need to be removed to remove the board. Is this correct?
I may have answered my own question. It appears I had to remove the nuts in order to get the board past the clutch pedal. I assume that the plate goes to the backside, and the rubber stopper shows through the cutout for the clutch?
