Schnikeys! I didn't keep track of the base gaskets . How do I figure that out please Stock 2.0 4 cylinder stock 94 flat top pistons
VaccaRabite
Jun 6 2013, 06:30 AM
Is this a double post from your base shim post or are you asking how to figure out your deck height?
stugray
Jun 6 2013, 08:42 AM
Typically you measure deck height before and after installing the shims. If you didnt do a "before" measurement, then you are SOL.
How far did you go in the assembly before you found that you had mixed up the gaskets? I took a fully assembled long block with engine tins and swapped the shims in about 4 hours.
Stu
