boxerboy
Nov 29 2004, 02:26 PM
From time to time I see a post that mentions an Optima battery being ideally suited for a 914. The problem is that there doesn't seem to be one that fits. Has anyone installed one of these sealed batteries (stock battery tray mount) in a 914? Any tips, or are we doomed to a future of lead acid induced corrosion.
Carlitos Way
Nov 29 2004, 04:02 PM
I believe a 34R is the right "fit" for the 914. Do a search on previous posts. Search for Optima+battery.
Good luck,
Carlos
anthony
Nov 29 2004, 04:18 PM
Can anyone find a 34R?
In any case the standard red top fits fine if you lengthen the ground cable. It's probably time for a new one anyway.
anthony
Nov 29 2004, 04:20 PM
BTW, I think I'd consider a Hawker Odyssey or a sealed Miata battery next time I need a battery for a 914. They are $50 cheaper.
machina
Nov 29 2004, 04:41 PM
I just put a 34R in my 986S. Fit perfect, didn't have to lengthen cables. Only modified the stock clamp to hold it down.
Only difference with the "R" model are the reversed + & - poles. Happens to be a big distributor for optima near my house that had it in stock.
Have an 34 optima in the 914 but my battery is up front.
kermit
Nov 29 2004, 07:03 PM
Yeah they fit, just the regular ol' red tops. sits on the factory battery tray nicely.
Word of caution though, there isn't much of a flange at the bottom of the battery to clamp it down. The battery fell over during an autocross. Now I have a metal strap that secures it in place.
anthony
Nov 29 2004, 07:16 PM
The new Optimas come with a black base that snaps on. It makes the base fit the stock battery clamp just right.
tracks914
Nov 29 2004, 09:18 PM
I don't know what you guys are paying for the optima but Walmart up here sells them for $138 for the 900cca and $159 for the100cca. The RV optima is a bit more.BTW these a CAN$$$
JB 914
Nov 29 2004, 09:23 PM
QUOTE(tracks914 @ Nov 29 2004, 07:18 PM)
I think mine was $100+tax at COSTCO
tracks914
Nov 29 2004, 09:27 PM
QUOTE(joe buckle @ Nov 29 2004, 07:23 PM)
$155CAN at COSTCO in Sudbury, ON. That's about $130US
Carlitos Way
Nov 29 2004, 09:56 PM
I looked at Costco, but couldn't find a 34R. Saw a couple of listings for them on e-bay tho... so I'll be getting mine from there if/when I get mine.
Gary
Nov 29 2004, 11:00 PM
Got a 51R for $130 shipped from:
Autobahn Motorsports. 8 lbs lighter than the 34 (although not light at 26 lbs). It's about an inch taller, but still fits in the stock mount.
dlo914
Nov 29 2004, 11:48 PM
at the FLAPS i work (AutoZone alhambra, ca 91801) at the red tops run for about $130 with a 3 year replacement warranty, and the yellow tops run for $160 w/ a 2 year replacement warranty. now with a 20% employee discount the reds run for $104 + tax
. id get one if only my battery tray didnt look like a square donut
