QUOTE(eyesright @ Jun 11 2013, 06:32 AM)
Wow, I like that clean look. Nice work. Can you explain and show photos of what you did? DIY or did you farm it out to an upholstry shop? Are the seat belt retractors covered? Is the perlon glued in or velcro-ed...etc?
Would like to see some photos of your process if you have the time.
Thanks.
No problem. I did this about 7 years ago and it still looks perfect. Since these photos I ditched the center pad as well. I really like the sparse look now that it is done. The pic posted above is how it looks today, complete with the PMB GT style door panels. :-)
Just put the Dynamat up with the self sticking backing.
Cut the Perlon to roughly the correct size and very carefully put it in place starting with the top edge. I used the factory cut edge of the Perlon for the top so it looks perfectly straight. I just used a 3M spray adhesive to put the Perlon on top of the Dynamat.
After trimming and stretching. One tip with the Perlon, it stretches very easily so don't go crazy and start pulling on it too hard. If you do, you'll stretch it too much and it will look like crap.
I used matching carpet for the bottom of the firewall to finish it off.
Hope this helps!
