I had a question on the brakes.
The last couple days, I noticed it was dripping a bit, and so tonight I took the wheel off and wiped it clean to make it easier to see where it was coming from. When I step on the brakes, it ONLY dripped around where the brake line nut screws into the side of the caliper.
I thought the logical thing was to tighten it, and I am not so sure I even moved it any, but anyway, it started to drip even more and so I backed it off, and tried to tighten it again, but it didn't change a thing.
I'm guessing it is a weirdo size of brake line that I would have to get, as I presume that is all that is wrong with it. I have like a shortie 7" line on the end of another brake line.
What do you think I would need to do to correct the problem?
I'm guessing the problem is the end of that brake line??
Please advise, Lyle
