dangrouche
Jun 15 2013, 01:04 PM
How many of you are paranoid of being rear ended? I certainly am. Here's my installation of a 24-LED brake light that I installed with a few bits from my workbench. I got this 24-LED from a Bang Good.com. That website gives free shipping. The current model is on sale for $5.19 and that model is SKU010514. I bought the 24-LED version, which they no longer stock and it cost me $4.55. Its $7.49 at AMAZON. NO RELAY OR OTHER ELECTRICAL PARTS NEEDED. I know I have seen these in the FLAPS for at least double or triple that. Anyway, as long as you can wait a couple of weeks, you can either buy it there or go to the FLAPS. I finished the install last night. This morning when I went to open the rear trunk, I see that I should installed the light closer to the rear window. Almost tore the thing off! Pic one shows the wrong way to do it. Pic two shows the wiring from the left rear tail light housing. I put on brass spades (get from FLAPS) that sisters the existing connections and no OEM wiring was cut or spliced to do this install. Pic three shows routing for two leads into the engine compartment into the engine compartment. Pic four shows how I drilled the plastic with a 1/8" bit and threaded the wiring. I also used speed clips (from car speaker install kits) and you see the galvanized metal in the pic. I stuck a patch of velcro as a vibration pad. Pic five shows the velcro in place. I also added a flat washer and a lock washer when I screwed it into place. Pic six shows the completed installation. I also covered the entire wiring in small plastic tubing and zip tied everything in place, leaving a large loop of wire so the engine lid can be opened. I considered installing this under the targa bar, but routing the wire would have been too much work and I did not want to use the double sided foam tape that came with the light. This install can quickly undone with a pair of dykes in a few minutes.
Bartlett 914
Jun 15 2013, 01:40 PM
I think it would look better forward of the grill
r_towle
Jun 15 2013, 03:57 PM
Cool job.
turk22
Jun 15 2013, 04:06 PM
really like how did the wiring, with nothing cut... very clean. I think I would like to figure out how to mount to the underside of the roll bar, but I think its a very smart idea to have a third brake light on these cars.
Great job!
bandjoey
Jun 15 2013, 08:01 PM
So does it work???
Show me the RED!
dangrouche
Jun 15 2013, 11:44 PM
okay, no one around to help me step on the pedal, so I had to put on self timer, one blurry and the other lit up
dangrouche
Oct 1 2013, 08:20 PM
I added a $5 strobe flasher to my 3rd brake light set up, so now the 3rd brake light flashes in a pulsed manner. I bought the two models of the flasher module from superbrightleds.com, model LSC-100A and LSC-100B. LSC-100B gives you continuous flash pulsing as you step on brake. LSC-100A gives a few strobe pulses then brake lite stays on solid. I put on push-terminals so I when my mood strikes, I can change the mode of the flashing. Sorry, I don't know how to attach a video file of the actual light flashing. You will have to look up a youtube search at the vendor website using the model numbers discussed above and you will get an idea of the flashing mode outputs.
I added a fuse assembly as well. Wiring is simple, two grounds off of the left terminal, the hot terminal off of the the light housing feeds the strobe unit black lead, and the red lead exiting the strobe unit connects to the hot feed to the 3rd brake light.
Click to view attachment Click to view attachment
RickS
Oct 1 2013, 10:15 PM
Click to view attachmentNice work and yes I am just as paranoid adding a high intensity strobing stop light from a motorcycle lighting company (4 pulses and then goes solid). I took a little different tack and mounted it under the top edge of the roll bar.
Great job and paranoia works since I mounted the same in my 82 SC
anderssj
Oct 2 2013, 06:56 PM
Nice work, and thanks for the tip on the LSC-100A . . . I need to look into that!
QUOTE(RickS @ Oct 2 2013, 12:15 AM)
Rick, nice look on the white car--very discrete. Do you have any info on the light? (vendor, PN, price, etc.)
Also, how did you mount it? 3M foam tape?
Where did you run the wiring?
I'm always looking for better ways to skin this cat . . . and both shown will help with my current set up.
Thanks!
Steve A-
76-914
Oct 2 2013, 07:09 PM
I like the strobe controller. Look out Wheelen.
kid914
Oct 2 2013, 07:13 PM
I wonder if the strobe module would work with a c4 3rd light??
RickS
Oct 2 2013, 10:32 PM
QUOTE(anderssj @ Oct 2 2013, 05:56 PM)
Thanks!
Steve A-
Hi Steve thanks for the kind words.
This is the source and a video of the compact but bright flashing LED brake light. I did not use the red wire for the running light, only the flashing brake: Knight Rider Non-Sequential LED
http://www.customdynamics.com/knight_rider...l_led_video.htmI used Dan's wiring method to the tail light and then discretely popped out the wires though the fixed wing of the engine grill next to the targa bar. I then removed the targa chrome trim and ran the wires under the trim and popped them out in the center of the bar - since it is very low voltage, I used a thin gauge speaker wire.
The light indeed is attached by 3M double stick tape.
The cost was $30.00 but felt that was cheap to save my ass. Here is the link to the page for the NON-SEQUENTIAL DUAL INTENSITY (not yelling but they sell several types). Scroll down around mid-page:
http://www.customdynamics.com/knight_rider_led_light_bar.htm
914forme
Oct 3 2013, 10:00 AM
Flashing lights are restricted to emergency vehicles so if the circuit goes completely dark you could have an issue with Johnny law.
That being said, these are used all over the place, you can get around the issue by having a second set of LEDS light up with the flash module, thus making pulse in intensity.
That being said, I have al the parts to install my third brake light for my current build, including a pulsing third brake light. Though my stuff was not sub $15. Ford GT third brake lights are not that cheap.
Cairo94507
Oct 4 2013, 07:50 AM
Stephen I would like to see your Ford GT 3rd brake light. Where will you attach it?
We are definitely incorporating a 3rd brake light into my build and I definitely want it to have the flash option as described above.
My last several cars, DD's, have these and they flash 3-4 times and then go solid. I like the extra visibility to wake up the commuters.
914forme
Oct 4 2013, 11:06 AM
QUOTE(Cairo94507 @ Oct 4 2013, 09:50 AM)
Plan is to mount it in the trim right below the roof. I will have to cut a small pocket into the metal behind the trim, then trim the trim to make it flush, it will protrude just slightly. It has been done on here before so not my original idea, just really liked it for my build. So I am um stealing it.
I found it!
Cairo94507
Oct 4 2013, 10:42 PM
That is what Scotty is going to do to incorporate a 3rd brake light into my car. I want it to be about 12 inches long and I would prefer the lens to be clear so it kind of disappears into the trim unless it you step on the brake pedal. Definitely has to be LED.
Nürburg Nomad
Oct 5 2013, 09:48 AM
QUOTE(Cairo94507 @ Oct 4 2013, 11:42 PM)
Then you'll want a 5th Gen Camaro 3rd brake light like I have done. This is the 2010-2013 model for the coupe (not convertible) and is a clear lens, which is the widest OEM produced 3rd brake light you can section into our trim with a clear lens that I'm aware of. After that the slight curvature of the roll bar trim would prevent any wider LED assembly.
Best part is the LED array is so shallow you shouldn't need to hack into the structure of the roll bar itself, assuming you carefully modify the plastic housing on the back you should just need zip a section of the lip off and the wiring can be run underneath the trim.
I ordered 2 from a salvage yard in Cleveland a few years back that had lots of 5th Gen Camaro's and they FedEx'd them to me for about $25 a piece. I tried a few local GM dealerships but they insisted it was only sold with a huge wiring harness leading up to it and the cost was very high; as it's not a part that should ever require replacement given it's location in the back window.
7TPorsh
Dec 16 2013, 02:56 PM
I had an extra...10 minutes...to this and did it with a minute to spare.
"NO EXCUSE GUYS...BUY THE LIGHT AND PUT IT ON!
Take one more factor out of someone hitting you.
I mounted the same $5 ebay light under the targa bar. Light is stick on and it sticks ok so far. Since the light mount is a bit of an angle the lens extends further back than the targa so at night you see more red...plus it can be adjusted.
I mounted just behind the chrom trim and tucked the really thin wires under the trim and down the sail panel trim...didn't remove the trim, just loosened a little to slip the wires under.
Into the side engine grill and under into the trunk, etc. like described in the above posts...invisible.
No pulse yet but I do notice (in daytime) that drivers behind me brake sooner. and keep an extra foot or two open after they stop. Maybe my perception is
Click to view attachmentClick to view attachment
7TPorsh
Rleog
Dec 16 2013, 07:30 PM
Well, I'll be amazed if this purchase goes through, but I just ordered this light from BangGood.com for $2.99 and no shipping charge. I'll let you (this thread) know if/when I get it. Paid with PayPal.
913B
Dec 16 2013, 08:28 PM
banggood.com, sounds like a porno store
whats a good length for them, the brake light strip that is
Is it coming from slow boat from china ? Can anyone vouch for the quality. I am willing to spend a few more $$, but if this one is good enough ??
dangrouche
Dec 16 2013, 09:47 PM
you get the pulse module from superbrightleds.com and the light strip from Banggood.com. I have made literally at least a dozen orders from that Chinese vendor and it takes under 3.5 weeks and have ALWAYS received what I ordered. You just have to be PATIENT. I have made at least a dozen orders in the last year and have never been stiffed. you can buy this light module from PepBoys or other FLAPS but you will pay triple what it costs from Bangood. My motto is find cheapest to the do the job. I have ordered LED bulbs for the entire car from all China vendors, as long as you have the patience to wait. I figure I drive the car so seldom anyway, I can wait for the light module, which BTW, can be had in multiple lengths. the pulse module is a domestic vendor (but I know its China made) and its free shipping as well. All told, if you can wait, you can get an effective 3rd brake light system for under $10. A decent lunch costs more than that !! IT does the job, after all, if you never get rear ended, its done its job. A third lite is better than none at all. Oh, actually, they do sell bedroom suprises for the ladies.
gothspeed
Dec 16 2013, 10:05 PM
QUOTE(RickS @ Oct 1 2013, 08:15 PM)
I really like that location for the light ......
pjhaun
Dec 16 2013, 10:57 PM
Here is what I did to mine. I used a similar flasher. It had 2 wires in and 2 wires out. I think the one I bought was designed for a motorcycle.
http://youtu.be/fq0o2fBhSaA
7TPorsh
Dec 17 2013, 01:48 PM
My light took about 2 1/2 weeks; came in a bubble pack bag that would cost me $4 at Staple. Amazed they can design, build, pack and ship this across the world for less than a pound of peanuts.
I bought the 24 LED version; they had a 32 version too
7TPorsh
Dec 17 2013, 01:50 PM
QUOTE(pjhaun @ Dec 16 2013, 08:57 PM)
http://youtu.be/fq0o2fBhSaAOh heck yeah!!!
computers4kids
Dec 18 2013, 08:43 AM
The 3rd brake lights from a Corvette 1986 to 1990 work nicely as well.
Mark
falcor75
Dec 18 2013, 09:37 AM
QUOTE(pjhaun @ Dec 17 2013, 05:57 AM)
http://youtu.be/fq0o2fBhSaAI'd love to hear the details of your setup, I wont do the flashing thing as that would fail my MOT over here but the long strip and strips in the rear lights look amazing.
scott_in_nh
Dec 18 2013, 11:16 AM
QUOTE(Rleog @ Dec 16 2013, 08:30 PM)
I have bought RC Helicopters from BangGood.
You will get the product, but it could take a month or more to reach you.
boxsterfan
Dec 18 2013, 11:25 AM
http://youtu.be/fq0o2fBhSaAWhere did you get the long strip?
bandjoey
Dec 18 2013, 06:27 PM
24" led strip at autozone $20. Used mine for a year on the targa chrome strip. No pics on my phone now. Will put one up later
pjhaun
Dec 18 2013, 09:00 PM
QUOTE(boxsterfan @ Dec 18 2013, 09:25 AM)
I bought 48" Flexible PVC LED lights on Ebay. They came from Hong Kong, which took about 1 1/2 weeks to get. They can be cut at every third light to shorten the length.
pjhaun
Dec 18 2013, 09:13 PM
QUOTE(falcor75 @ Dec 18 2013, 07:37 AM)
I bought flexible pvc led lights on ebay. They came from Hong Kong, which took about 1 1/2 weeks to get. What I did I bought two spare tail light assemblies and took out the insides to mount plexi glass to attach the pcv flexible led lights to. The led lights come in different colors. I used red and white. I guess I should have used orange for the turn signal instead of red.
Rleog
Jan 2 2014, 03:48 PM
I ordered the 32 LED brake light on 12/16, paid $2.99 viaPayPal (that included shipping), and it arrived today, in a postal pouch.
