I started to remove my muffler and heat exchange (left side) due to a noisey exhaust leak. Come to find out that the nuts were so tight that the studs came with the nuts - right off!
I have one nut that is almost completely stripped that I can't get to - to take off. I'm thinking I might have to cut the SS heat exchanger to get to this unless someone has a better idea. Okay back to the real problem.
I've done some research, but still need some help/advice. I've read up on past threads that recommend a 8mm helicoil, tap, and insertion tool, and JB weld. Not forgetting the drill bit that is recommended by the 8mm helicoil package.
First - some of my studs unscred themselves off - should i just JB weld and screw back on?
2nd - can't I just re-tap the existing hole, buy 8mm studs and JB weld?
3rd - is it just best to use the 8mm helicoil kit?
4th - do I have to drop the engine to do this? (I hope not - I'm a rookie)
thanks for all the input and help.
