914ltd
Jun 17 2013, 09:34 AM
Prefer 1973 and not machined early wheels because of design difference.
Please spin them to make sure they are absolutely straight. I already have a pile of bent ones. Thanks, Brad
hot_shoe914
Jun 17 2013, 12:34 PM
QUOTE(914ltd @ Jun 17 2013, 10:34 AM)
Let me know if you don't find anything. I have a set of 4 with tires mounted I was going to put racing tires on. I might let them go but I need to check them first.
Shoe
Mblizzard
Jun 17 2013, 12:46 PM
Brad I have 5. Not sure if they are 1973. Is there a way to tell the year? Probably stamped on them but thought I would just in case it was not obvious. They are just sitting there so just let me know if you wind up needing them.
cpavlenko
Jun 17 2013, 01:20 PM
looking for this pedrini wheels, there of the 914 now and for sale....U can contact www.aircooledsonly.com if u want them. $150.00 for two. if u need more info let me know.
Mblizzard
Jun 17 2013, 07:56 PM
QUOTE(Mblizzard @ Jun 17 2013, 10:46 AM)
I think mine are the early ones as they end in 00.
914Sixer
Jun 17 2013, 08:22 PM
Early 00 wheels can be machined easily IF you can find some one to do the work for a reasonable price. I took a Fuchs wheel and let them measure it and then they cut the the inset down.
Mblizzard
Jun 17 2013, 09:59 PM
Because mine is a late model I guess I will have to look into that.
914ltd
Jul 10 2013, 08:18 PM
Still looking! I will buy 1 early if it is straight. Thanks, Brad
Mblizzard
Jul 10 2013, 08:40 PM
QUOTE(914ltd @ Jul 10 2013, 06:18 PM)
What is the best way to determine straightness? The eyeball test will find the big things but it can miss a lot.
Krieger
Jul 10 2013, 08:48 PM
Hey Brad, I saw some on The Samba the other day. Don't know if they are early or late.
914ltd
Jul 11 2013, 09:39 AM
A good way to check for straightness is to stack one wheel on the other and check 360 degrees for ANY gaps between the 2 wheels then stack so the other 2 surfaces are in contact. Vary rarely the wheels are bent at the center only but this should work. Brad
