Mark Henry
Nov 30 2004, 02:54 PM
I bought a bunch of tools at an auction sale a couple of months ago. Some of the stuff I don't know exactly what it's for, but I think it's mostly aircooled bug factory transmission tools.
Some I do know and now use...the silver thing is a stand for a T4 head, stands the guide straight up and down.
The green unit is a factory T1 valve spring compressor and behind that is a factory valve seat cutter set.
Jake Raby
Nov 30 2004, 03:08 PM
Man, thats sweet stuff!
ClayPerrine
Nov 30 2004, 03:10 PM
of what you want us to ID.........
Mark Henry
Nov 30 2004, 03:11 PM
The unknown tools, all VW factory tools …sorry bad pic
it’s a lot of tools for sure.
Mark Henry
Nov 30 2004, 03:22 PM
My IP is crapping out big time….sympatico.ca SUCKS …I need a new IP
Mark Henry
Nov 30 2004, 03:24 PM
The tool top/left is the factory tool for measuring the spacer between 3rd and 4th gear.
The silver tool may be for a Porsche. Tool # P208
The tool with the wing nut is an ATE unit part # 2314-1300 2
I think the big one top/right is for putting a dial indicator on the gear stack.
Mark Henry
Nov 30 2004, 03:35 PM
I have this link, but most of the numbers don’t match up and this doesn’t tell me much anyways.
http://www.samstagsales.com/vwaudi_ref.htm
davep
Nov 30 2004, 03:37 PM
Mark
Send me a list of any numbers on the tools. I'll go through the shop manuals and ID the tools as best I can.
DaveP
Mark Henry
Nov 30 2004, 05:18 PM
It’s not the whole list... but part (tool) #’s
VW 123b/1
VW 182
VW 202c
VW 270
VW 278a
VW 293/5
VW 314
VW 340/5
VW 361/2
VW 381/5a
VW 460/3
VW 521/8
VW 541/3
VW 554
VW558
VW 650
VW 796
VW 2052/1
VW 2156
049 903 143c
P 208
P 235
P 357a
W160
302
2051
3026
3075
3163
3846
5338m
9100a
9148
G-25 (SLW)
9247/4 (SLW)
9247/3 (SLW)
30-23
30-28 (TBN)
40-405
2056 W-P 202 (SALTUS)
50 0287.001.001
JeffBowlsby
Nov 30 2004, 09:45 PM
I am in the process of creating a webpage listing and illustrating all the all the factory tools from the 914 factory manuals. I have several phtoos of most of the tools...I just need to finish the photos and post the webpage. Here is an excerpt of my 914 tool list:
Special 914 Porsche Tools from the Factory repair manual
Tool Description Use
Lever 1 Locally made lever Removes shiftknob
Lever 2 Locally made lever Front trunklid spring adjuster
P 1a Electric piston warmer Why is this tool needed?
P 2a Piston pin mandrel Removes/installs piston wrist pins
P 8 Piston ring compressor Piston ring compressor
P 10b Valve spring adjuster
P 25a Measuring gauge Measures fuel flow into carbs
P 37 Holding plate Holds input shaft
P 66a Pulling hook
P 74 Screwdriver socket
P 83 Piston resetting fixture Brake caliper piston compressor
P 84 Piston gauge Rear brake piston venting clearance gauge
P 86 Pulling hook Brake pad extractor
P 87 Measuring tool Dial gauge mounting fixture
P 119 Allen-head adapter for cylinder head nuts
P 120a T-wrench (swivel) for intake stacks 914/6 only?
P 140 Holding nut for cylinder
P 200 Valve spring compressor plate 914/6 valve spring compressor
P 201 Engine bench mount Heavy-duty engine / transaxle mount
P 202 Camshaft wrench
P 203 Camshaft nut adapter
P 206 Valve guide plug gauge Measures valve stem clearance
P 207 Dial gauge mounting fixture For measuring crankshaft endplay
P 208 Fan belt pulley wrench For 914/6 only
P 209 Crankshaft holding fixture
P 212 Sprocket wheel dowel extractor (puller)
P 213 Valve feeler gauge For 914/6 only
P 214 Chain tensioner clamp For 914/6 only
P 214b Adjusting ring
P 215 Oil seal installer
P 215c Flywheel retainer Holds flywheel and crankshaft secure
P 216 Oil seal installer Installs front crankshaft oil seal
P 217 Heat exchanger box wrench For 914/6 only
P 218 Flywheel bushing installer
P 221 Connecting rod holder
P 222 Timing chain holder For 914/6 only
P 226a Level measuring gauge For 914/6 only
P 252 Socket insert 32mm For assembling gear stack
P 253 Thrust piece
P 254 Driver / extractor thrust pieces (3 parts) For installing transaxle bearings
P 255
P 256 Holding plate Holds gear stack
P 256b Thrust plate Bearing installation tool
P 258 Gear measuring gauge (with adjusting piece)
P 259 Measuring device (4 part with disc from P 357)
P 260 Holding plate (shift rod holder)
P 261 Torque gauge Measures torque of assembled differential
P 262
P 263 Thrust piece
P 264 Thrust piece (same as P 264b?)
P 264b Thrust piece (same as P 264?) Bearing installation tool
P 265b Thrust piece
P 280b 4-point socket (spanner) Ball joint tool
P 284b Test fixture for steering arm (for vehicle Type 914/6) (Same as Tool p 284c?) Verifies steering knuckle dimensional tolerances
P 285b Adjusting gauge for steering gear Verifies steering gear dimensional tolerances
P 286b Test fixture for steering knuckle and shock absorber strut (for vehicle Type 914/6) (Same as P 286c?) Verifies front wheel strut dimensional tolerances
P 288b Testing fixture for transverse control arm Verifies front wheel control arm dimensional tolerances
P 290 Hinge bolt remover Removes side door hinge pins
P 297a Removing mandrel Removes rear wheel bearing
P 298b Assembly fixture (rear wheel hub)
P 299 Press mandrel (for shift knob) Installs shift knob onto shift lever
P 302 Thrust piece Installs rear wheel bearing
P 303 Claws for VW 340 Upper claws for use with VW 340 - for installing rear coil springs onto struts
P 304 Lever For installing/releasing rear trunk lid torsion bars
P 351 Holding plate (use VW 307a or P 201) Sportomatic adapter plate for engine mounting stand
P 353 Thrust piece
P 354 Thrust piece
P 355 Holding plate
P 356b Holding fixture
P 357 Measuring device (5 parts)
P 358 Thrust piece
P 359 Thrust piece
P 360 Thrust piece / Holding plate
P 361 Thrust piece
P 362 Thrust piece
P 364 Sleeve
P 365 Bushing
P 369 Mandrel
P 379 Mandrel
P 860 Door frame template - Right
P 861 Door frame template - Left
P 862 Windshield template
P 863 Alignment and welding jig (Celette jig for front end)
VW 123d Piston ring strap
VW 124a Notch(ing) punch
VW 124b Peening punch
VW 161a Circlip spreader (pliers)
VW 184 Clutch disk support ring (sportomatic) or 'holding ring for driven plate' or 'holding ring for carrier plate'
VW 185 Blower hub remover For removing blower fan
VW 190 Fitting fixture for crankshaft sealing ring (impeller end)
VW 191 Fitting fixture for crankshaft sealing ring (flywheel end)
VW 202 Puller
VW 207 Mandrel
VW 207c Piston pin mandrel Removes/installs piston wrist pins
VW 214f/70 Inspection and reaming fixture for connecting rod
VW 215c Holding clip for flywheel (flywheel lock) Holds flywheel and crankshaft secure
VW 228b Puller (for starter bushing)
VW 244 Installing sleeve
VW 244b Fitting sleeve
VW 262 Mandrel
VW 307a Holder (engine bench mount)
VW 311s Valve spring compressor
VW 313 Clamping support Use with P201 to support engines and transaxles
VW 340 Clamping fixture for rear suspension coil springs Use with P303 to remove/install rear suspension coil springs
VW 385/1 Measuring mandrel
VW 385/4 Centering disc
VW 385/12 Measuring pin
VW 385/14 Dial indicator extension (12.3 mm)
VW 385/16 Setting gauge (R=63.50 mm)
VW 385/17 Measuring plate
VW 400 Repair press
VW 401 Press plate (Thrust plate) Support plate with various reveals to support various items while using a mechanical press
VW 402 Press plate (Thrust plate) Support plate with various reveals to support various items while using a mechanical press
VW 405 V-blocks punch (2 parts) Support blocks for round shafts, useful while performing other operations on shafts
VW 406 Pressure pin?
VW 407 Pressure pin (pressure die) Mechanical press tool
VW 408a Block
VW 409 Pressure ram (punch) Mechanical press tool
VW 410 Punch (thrust piece) (pressure die) Mechanical press tool
VW 411 Thrust piece (punch) (pressure pin) Mechanical press tool
VW 412 Block (thrust piece) (pressure pin) Mechanical press tool
VW 415a Tube section, 60mm diameter (2.4") Mechanical press tool
VW 416b Press tube (pipe tool) Mechanical press tool
VW 418a Tube, 31.5mm diameter (1.24") Mechanical press tool - Sportomatic transaxle
VW 420 Tube
VW 421 Press tube (pipe) (28 mm diameter) (1.1")
VW 422 Tube (slotted)
VW 423 Pipe
VW 426 Tube section Mechanical press tool
VW 427 Guide sleeve
VW 428 Guide sleeve, tapered
VW 428a Guide sleeve, tapered
VW 432 Pressure piece Mechanical press tool
VW 433 Pressure piece
VW 438 Thrust piece Mechanical press tool
VW 439 Guide piece (offset) Mechanical press tool
VW 442 Thrust piece
VW 447f Pressure plate Mechanical press tool
VW 447g Pressure plate Mechanical press tool
VW 447h Pressure plate Mechanical press tool
VW 447i Pressure plate Mechanical press tool
VW 449c Thrust piece
VW 455 Thrust piece
VW 457 Press adapter plates for bearings of differential
VW 459/2 Thrust tube
VW 472/1 Pressure piece
VW 472/2 Tubing (spacer sleeve)
VW 612/3 Transmission extension for VW 612/4
VW 612/4 Engine support for garage jack
VW 637/2 Hub cap puller
VW 659/2 Dial guage holder
VW 661/2 Tester for oil cooler
VW 662/2 Pressure tester
VW 674/1 Multiple cross wrench
VW 689/1 Clamping plate with wear measuring instrument for valve guides
VW 771 Multipurpose tool (local manufacture)
VW 783 Riveting tool for clutch disk
VW 798/2 Actuating device for carburetor
VW 801 Crankshaft support plate
VW 803 Puller for oil pump cover
VW 1218 D-Jetronic fuel injection system tester
EFAW 193 D-Jetronic fuel injection system tester, with adapter
EFAW 238 D-Jetronic fuel injection system tester
JeffBowlsby
Nov 30 2004, 09:51 PM
Here is P200 for instance:
Mark Henry
Dec 1 2004, 07:40 AM
Ok so these would be:
top, P 208 Fan belt pulley wrench For 914/6 only
middle, P 202 Camshaft wrench
bottom, P 302 Thrust piece Installs rear wheel bearing
Mark Henry
Dec 1 2004, 08:03 AM
This is P 357a....so am I missing the other 4pcs?
For measuring what?
Mark Henry
Dec 1 2004, 08:08 AM
Here is a better pic of the smaller tools
davep
Dec 1 2004, 09:32 AM
Mark Henry
Dec 1 2004, 10:43 AM
So...is this a ball joint spanner for a 911???
It only has 2 teeth they measure about 2.370 on the OD.
Mark Henry
Dec 1 2004, 10:51 AM
The one on the left is the above tool, it's about a foot long with a 3/8 drive. Can't read the part #
Center is a new one for pressure or vacuum testing something, part # T3506
Pretty sure the one on the right is for pressing the timing gear on a T4 crank. Again part 3 hard to read...# 40-205??
davep
Dec 1 2004, 10:57 AM
That 'looks' more like the tool for the front strut shock nut due to its length. The ball joint tool is similar, but rather short. It looks to be missing two teeth. BTW, I need to get such a nut off of a strut very soon now. I was just about to make my own tool up.
Root_Werks
Dec 1 2004, 11:05 AM
Tools
Mark Henry
Dec 1 2004, 11:14 AM
Close Dave but no cigar....it's a bit smaller, maybe it's for a super beetle...damn.
BTW it only had two teeth, I don't think the tool has ever been used, no marks on the teeth at all.
Thanks for the links Dave, they helped, but the last one is just the std. bug tools that you can get today from any bug shop, including me.
Mark Henry
Dec 1 2004, 01:03 PM
BTW how much do you think I paid for all this stuff????
Oh…. plus a 36hp and a 1200cc T1 Malhe german piston and cylinder kits, 2 reground 1200 cranks, about $150 worth (my cost) of new T1 engine bearings, half dozen new hex plugs for 914 inside rear calliper, NOS T4 dizzy drive in box, assorted timecerts and studs, assorted T1 small parts and a bunch of stuff I could care less about…ie new W/C rods and piston sets, etc.
Most were in job lots and if I wanted one tool I had to take them all.
Mark Henry
Dec 1 2004, 07:09 PM
What??? No one wants to try a guess on the price?
DrifterJay
Dec 1 2004, 07:15 PM
10 bucks
Mark Henry
Dec 1 2004, 09:20 PM
Nope...$250 Canadian (about $200US)
But I didn't get the steal of the day...Mike (of Mike's 914) picked up a pair of 914/6 5 bolt Malhe's for $40...Then the prick (
) stuck them on ebay and sold them for over $500US
A nice little profit I'd say.
newdeal2
Dec 1 2004, 09:39 PM
Oh man! another prick for profit guy!
JeffBowlsby
Dec 1 2004, 10:09 PM
This is the only photo/info I have on P357:
