newdeal2
Nov 30 2004, 11:22 PM
In the engine bay, what is the white wire by the dizzy for, the red/green towards the pass side tin and where does the large bundle of grounds from the center of the harness bolt to ?? I missed these in my notes.
scotty914
Nov 30 2004, 11:55 PM
white wire is either oil pressure sender or if a 1.8 its the sender from the coil to the brain ( not to sure )
group of grounds to top center of motor should be 3 spade terminals on motor split line
red green oil temp sender
JeffBowlsby
Dec 1 2004, 12:01 AM
The single white wire if its from the FI harness is for the Thermotime switch down near the tin, top passenger side of the engine.
tbox56
Dec 1 2004, 09:39 PM
see if you can find the wire on one of these electrical digrams
Pelican Parts elecrtical digrams
markb
Dec 1 2004, 11:30 PM
The white wire on my 1.7 is for the AAR.
