QUOTE(MikeM @ Jun 23 2013, 07:51 AM)
Hi all...while swapping transmissions I decided to replace my leaking shift shaft seal.
Well, the shaft came out of the trans and now I'm not sure of how to re-install it.
Does it get held in place by the "console"?
Thanks as always....
Mike
OK. I'm guessing it's a side shift trans, because you don't give us much information to go on. Drain the trans (first making sure the fill plug will come out!), remove the console, and take a look. If the shaft came out, something's missing/broken. Sounds to me like you've sheared a roll pin. For a good blow up of the assembly, see this link:
http://www.porsche.com/usa/accessoriesands...partscatalogue/Select 914, go to transmission and then find the linkage pictures. Scroll to the appropriate picture.
The Cap'n
