QUOTE(Dave_Darling @ Jun 24 2013, 09:58 AM)
QUOTE(malcolm2 @ Jun 23 2013, 11:21 AM)
1.8 L-Jet Injection:
GREEN wire from the distributor.... + or - on the coil?
single wire from the FI harness.... + or - on the coil?
Single connector with 2 wires from the Ignition Harness.... + or - on the coil?
Probably + ; should be black with a RED stripe, and have power when the key is on.
Single wire from the IG harness.... + or - on the coil?
Probably - ; should be black with a PURPLE stripe, and be thinner than the "probably +" wire above.
More details:
The green wire carries the signal from the ignition points. It tells the coil when to fire.
The white wire from the FI harness takes the points signal and carries it to the FI so the FI knows when ignition is happening and how fast the engine is turning.
The black/red wire provides power to the coil.
The black/purple wire carries the signal from the points up to the tach so the tach can tell us how fast the engine is turning over.
--DD
Great, thanks so much.... I was a bit wrong. The single wire from the FI harness was on the +. Jeff's diagram says, "coil" on one page and "coil =1" on the other page which would be -, but I thought he was referring to the ECU connector wiring. Anyone have ideas on the + double wire with a single connector on the Ig harness? What is the 2nd wire in that harness that has not been mentioned?
Strange thing about the coil. In the center hole that connects to the center of the distributor there was no metal. nothing, just a hole. The coil is one thing I never tested, never really looked at until now. And once I got it off the fan housing.... there were markings for 1 and 15. Crazy, I never saw that and once it was mounted I could not see it.
Thanks,
Clark
